Дефектные обновления [Core], [Extra]
Вопросы по менеджеру пакетов и обновлениям
VyacheslavS
vall: система с KDE перестала выходить из режима сна. Аналогичное поведение и на lts-ядре.
Тёмный экран монитора, -- и только кнопка reset системного блока позволяет вновь получить контроль над десктопом.
Подтверждаю, весь день только и занимаюсь нажатием кнопки reset.
vall:GPU: NVIDIA GeForce GTX 1050 Ti [Discrete]
[ 2395.216137] PM: suspend entry (deep)
[ 2395.253101] Filesystems sync: 0.036 seconds
[ 2395.284617] Freezing user space processes
[ 2395.286943] Freezing user space processes completed (elapsed 0.002 seconds)
[ 2395.286947] OOM killer disabled.
[ 2395.286948] Freezing remaining freezable tasks
[ 2395.287904] Freezing remaining freezable tasks completed (elapsed 0.000 seconds)
[ 2395.287919] printk: Suspending console(s) (use no_console_suspend to debug)
[ 2395.317967] sd 2:0:0:0: [sdc] Synchronizing SCSI cache
[ 2395.318022] sd 1:0:0:0: [sdb] Synchronizing SCSI cache
[ 2395.318725] ata2.00: Entering standby power mode
[ 2395.318771] ata3.00: Entering standby power mode
[ 2395.321316] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 2395.323176] ata1.00: Entering standby power mode
[ 2395.714288] ACPI: PM: Preparing to enter system sleep state S3
[ 2395.714472] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 2395.715021] ACPI: PM: Saving platform NVS memory
[ 2395.715178] Disabling non-boot CPUs ...
[ 2395.717516] smpboot: CPU 1 is now offline
[ 2395.719737] smpboot: CPU 2 is now offline
[ 2395.722027] smpboot: CPU 3 is now offline
[ 2395.724515] smpboot: CPU 4 is now offline
[ 2395.726350] smpboot: CPU 5 is now offline
[ 2395.728942] smpboot: CPU 6 is now offline
[ 2395.730753] smpboot: CPU 7 is now offline
[ 2395.737402] ACPI: PM: Low-level resume complete
[ 2395.737419] ACPI: PM: Restoring platform NVS memory
[ 2395.737499] LVT offset 0 assigned for vector 0x400
[ 2395.742903] Enabling non-boot CPUs ...
[ 2395.743221] smpboot: Booting Node 0 Processor 1 APIC 0x11
[ 2395.751630] ACPI: \_PR_.P002: Found 2 idle states
[ 2395.751875] CPU1 is up
[ 2395.752138] smpboot: Booting Node 0 Processor 2 APIC 0x12
[ 2395.762257] ACPI: \_PR_.P003: Found 2 idle states
[ 2395.762514] CPU2 is up
[ 2395.762782] smpboot: Booting Node 0 Processor 3 APIC 0x13
[ 2395.772294] ACPI: \_PR_.P004: Found 2 idle states
[ 2395.772597] CPU3 is up
[ 2395.772870] smpboot: Booting Node 0 Processor 4 APIC 0x14
[ 2395.782329] ACPI: \_PR_.P005: Found 2 idle states
[ 2395.782654] CPU4 is up
[ 2395.782901] smpboot: Booting Node 0 Processor 5 APIC 0x15
[ 2395.792365] ACPI: \_PR_.P006: Found 2 idle states
[ 2395.792730] CPU5 is up
[ 2395.793001] smpboot: Booting Node 0 Processor 6 APIC 0x16
[ 2395.802374] ACPI: \_PR_.P007: Found 2 idle states
[ 2395.802755] CPU6 is up
[ 2395.803002] smpboot: Booting Node 0 Processor 7 APIC 0x17
[ 2395.812472] ACPI: \_PR_.P008: Found 2 idle states
[ 2395.812921] CPU7 is up
[ 2395.822827] ACPI: PM: Waking up from system sleep state S3
[ 2395.836870] usb usb8: root hub lost power or was reset
[ 2395.836875] usb usb9: root hub lost power or was reset
[ 2396.121338] usb 8-1: reset high-speed USB device number 2 using xhci_hcd
[ 2396.307972] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2396.308002] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2396.308698] sd 0:0:0:0: [sda] Starting disk
[ 2396.308726] sd 1:0:0:0: [sdb] Starting disk
[ 2396.308829] ata1.00: configured for UDMA/133
[ 2396.308855] ata2.00: configured for UDMA/133
[ 2396.631165] OOM killer enabled.
[ 2396.631167] Restarting tasks ... done.
[ 2396.638865] random: crng reseeded on system resumption
[ 2396.638876] PM: suspend exit
Без проблем.
Продолжаем обсуждение здесь viewtopic.php?t=3157
SmiGes
Где-то с месяц назад началась проблема с пакетом gdk-pixbuf2 . Заметил так: использую DE Mate, перестали сохранятся скриншоты (при этом при сохранении скриншота в списке процессов стало появляться большое количество процессов bwrap.) Поискав в англоязычном форуме, увидел что люди там боролись с этой проблемой устанавкой пакета из AUR gdk-pixbuf2-noglycin (а сейчас ещё и второй надо пакет собирать librsvg-noglycin). Хотел спросить у всех такая проблема, или это только на mate проявляется?
SmiGes:у всех такая проблема, или это только на mate проявляется?
ХFCE - no problem). Всё отлично работает. Обновления последние.
BendalfRU
микрофон не работает.
убунту лив запустил на тойже машине, работает без манипуляций.
тему про это уже создавал в разделе мультимедиа
https://archlinux.com.ru/forum/viewtopic.php?t=5319
BendalfRU
bazel , dbeaver невозможно установить одновременно, конфликт jre21-openjdk-21.0.9.u10-1 and jdk21-openjdk-21.0.9.u10-1
а если се таки установили, то одна из программ работать не будет
Последний раз редактировалось BendalfRU 23.11.2025 18:59, всего редактировалось 1 раз.
смотри в корень:
- jre21-openjdk 21.0.9.u10-1 ... https://archlinux.org/packages/extra/x8 ... 1-openjdk/
Conflicts: jdk21-openjdk, jre21-openjdk-headless
- jdk21-openjdk 21.0.9.u10-1 ... https://archlinux.org/packages/extra/x8 ... 1-openjdk/
Conflicts: jre21-openjdk, jre21-openjdk-headless
+ гугл
BendalfRU:bazel , dbeaver невозможно установить одновременно
$: sudo pacman -S bazel dbeaver
[sudo] пароль для alien:
разрешение зависимостей...
проверка конфликтов...
Будет загружено:    466,61 MiB
Будет установлено:  666,53 MiB
:: Приступить к установке? [Y/n]
:: Получение пакетов...
 java-runtime-com...     5,0 KiB  7,96 KiB/s 00:01 [######################] 100%
 java-environment...     2,7 KiB  43,9 KiB/s 00:00 [######################] 100%
 libnet-2:1.3-1-x...   295,0 KiB   331 KiB/s 00:01 [######################] 100%
 bazel-8.4.2-1-x86_64   37,7 MiB  5,37 MiB/s 00:07 [######################] 100%
 dbeaver-25.2.5-1...    96,8 MiB  10,9 MiB/s 00:09 [######################] 100%
 jdk21-openjdk-21...   331,8 MiB  13,3 MiB/s 00:25 [######################] 100%
 Total (6/6)           466,6 MiB  18,6 MiB/s 00:25 [######################] 100%
(6/6) проверка ключей                              [######################] 100%
(6/6) проверка целостности пакета                  [######################] 100%
(6/6) загрузка файлов пакетов                      [######################] 100%
(6/6) проверка конфликтов файлов                   [######################] 100%
:: Обработка изменений пакета...
(1/6) установка java-runtime-common                [######################] 100%
For the complete set of Java binaries to be available in your PATH,
you need to re-login or source /etc/profile
Please note that this package does not support forcing JAVA_HOME as former package java-common did
(2/6) установка libnet                             [######################] 100%
(3/6) установка java-environment-common            [######################] 100%
(4/6) установка jdk21-openjdk                      [######################] 100%
Дополнительные зависимости для 'jdk21-openjdk'
    java-rhino: for some JavaScript support
    alsa-lib: for basic sound support [установлено]
    gtk3: for the Gtk+ 3 look and feel - desktop usage [установлено]
(5/6) установка bazel                              [######################] 100%
(6/6) установка dbeaver                            [######################] 100%
:: Запуск post-transaction hooks...
(1/4) Arming ConditionNeedsUpdate...
(2/4) Updating the DBeaver bundles.info database...
(3/4) Updating icon theme caches...
(4/4) Updating the desktop file MIME type cache...
BendalfRU
ALiEN:???
и обе запускаются , работают ?
BendalfRU:и обе запускаются , работают ?
BendalfRU
ALiEN:и обе запускаются , работают ?
ClipGrab у меня 2ой по популярности после браузера
после этих манипуляций перестал запускаться и исчез из extra,
я очень расстроился
UPD; установил flatpack ЗАРАБОТАЛО
Последний раз редактировалось BendalfRU 11.12.2025 11:14, всего редактировалось 1 раз.
