[РЕШЕНО] Перестал запускаться Soundconverter
waldym
После последних Update, не запускается Soundconverter. Пару недель назад, все работало. Если запускаю из терминала, появляются ошибки:
[waldy@archlinux ~]$ soundconverter
ERROR: Disabling aac-enc output. Do you have "gst-plugins-bad" installed?
soundconverter 4.0.3
ERROR: audio/x-m4a fdkaacenc,faac,avenc_aac is not supported, a gstreamer plugins package is possibly missing.
Traceback (most recent call last):
  File "/usr/bin/soundconverter", line 241, in <module>
    gui_main(NAME, VERSION, GLADEFILE, files)
  File "/usr/lib/python3.10/site-packages/soundconverter/interface/ui.py", line 533, in gui_main
    window = SoundConverterWindow(builder)
  File "/usr/lib/python3.10/site-packages/soundconverter/interface/ui.py", line 59, in __init__
    self.prefs = PreferencesDialog(builder, self.widget)
  File "/usr/lib/python3.10/site-packages/soundconverter/interface/preferences.py", line 78, in __init__
    self.set_widget_initial_values()
  File "/usr/lib/python3.10/site-packages/soundconverter/interface/preferences.py", line 161, in set_widget_initial_values
    self.change_mime_type(current_mime_type)
  File "/usr/lib/python3.10/site-packages/soundconverter/interface/preferences.py", line 379, in change_mime_type
    self.update_example()
  File "/usr/lib/python3.10/site-packages/soundconverter/interface/preferences.py", line 265, in update_example
    generator.generate_target_uri(sound_file, for_display=True)
  File "/usr/lib/python3.10/site-packages/soundconverter/util/namegenerator.py", line 451, in generate_target_uri
    filename = self._get_target_filename(sound_file)
  File "/usr/lib/python3.10/site-packages/soundconverter/util/namegenerator.py", line 430, in _get_target_filename
    self.fill_pattern(sound_file, self.basename_pattern),
  File "/usr/lib/python3.10/site-packages/soundconverter/util/namegenerator.py", line 371, in fill_pattern
    result = pattern.format(**mapping)
ValueError: Single '}' encountered in format string
"gst-plugins-bad" установлен.
Пробывал переустанавливать, переустанавливается без ошибок. Не подскажите, в чем причина?
Последний раз редактировалось waldym 10.09.2022 00:24, всего редактировалось 1 раз.
Без проблем.
Видимо имеет место, не полного обновления системы.
waldym
И как это исправить?
[waldy@archlinux ~]$ sudo pacman -Syyu
[sudo] пароль для waldy:
:: Обновление баз данных пакетов...
 core                  157,2 KiB   982 KiB/s 00:00 [######################] 100%
 extra                1748,9 KiB  21,3 MiB/s 00:00 [######################] 100%
 community               6,9 MiB  27,4 MiB/s 00:00 [######################] 100%
:: Запускается полное обновление системы...
 делать больше нечего
waldym:И как это исправить?
Попробуй через рефлектор, зеркала актуальные подобрать.
waldym:Не подскажите, в чем причина?
Причина похоже в python, который в зависимостям у soundconverter.
Если причина действительно в этом, подожди недельку пока не исправят.
Рекомендую также погулить по этим логам, может и набредешь на причину.
PS - при гуглеже сразу же выскочила похоже проблема в 2021 году https://bugs.launchpad.net/soundconverter/+bug/1934517
В подробности не вникал, привожу часть логов ... один в один, как у тебя ...
    gui_main(NAME, VERSION, GLADEFILE, files)p/code]
waldym
Спасибо за помощь, проблема решена. Просто удалил файл ~/.config/dconf/user и Restart. Все работает как и должно.
waldym - просьба отметить, что решено - отредактировать 1-ый пост, перед названием темы прописать [РЕШЕНО]
